メインコンテンツにスキップ
HP ProBook 4320t Touchpad Replacement Guide
必要な工具と部品
  1. HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: 手順 1、 2の画像 1 HP ProBook 4320t Touchpad Replacement Guide, Battery Removal: 手順 1、 2の画像 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Touchpad Replacement Guide, Screws: 手順 2、 2の画像 1 HP ProBook 4320t Touchpad Replacement Guide, Screws: 手順 2、 2の画像 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Touchpad Replacement Guide, Flip: 手順 3、 1の画像 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Touchpad Replacement Guide, Push N Lift: 手順 4、 1の画像 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: 手順 5、 1の画像 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Touchpad Replacement Guide, Careful Now: 手順 6、 2の画像 1 HP ProBook 4320t Touchpad Replacement Guide, Careful Now: 手順 6、 2の画像 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: 手順 7、 1の画像 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Touchpad Replacement Guide, Unscrew: 手順 8、 1の画像 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Touchpad Replacement Guide, Slide the Panel Off: 手順 9、 1の画像 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Touchpad Replacement Guide, Lift up Carefully: 手順 10、 1の画像 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Touchpad Replacement Guide, Disconnect Wire: 手順 11、 1の画像 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
  12. HP ProBook 4320t Touchpad Replacement Guide, Unscrewing: 手順 12、 1の画像 1
    • Unscrew the two (2.5 mm Phillips) screws on the touch pad retention panel (Use Phillips #0 screw driver).
  13. HP ProBook 4320t Touchpad Replacement Guide, Remove Retention Panel: 手順 13、 1の画像 1
    • Slightly push the touch pad retention panel forward to remove from clasp and lift up.
  14. HP ProBook 4320t Touchpad Replacement Guide, Touch Pad Screws: 手順 14、 1の画像 1
    • Unscrew the following two (2.0 mm Phillips) screws attached to the touchpad (Use Phillips #0 screw driver).
  15. HP ProBook 4320t Touchpad Replacement Guide, Remove Touchpad: 手順 15、 1の画像 1
    • Slightly lift up the bottom of the touchpad and pull towards you to free the touchpad from the casing
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Joshua
メンバー登録日: 09/23/14
134 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 9-5, Blackwell Fall 2014 USF Tampa, Team 9-5, Blackwell Fall 2014人のメンバー
USFT-BLACKWELL-F14S9G5
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,466
