メインコンテンツにスキップ
HP Photosmart c4780 Scanner Glass Replacement
必要な工具と部品
  1. HP Photosmart c4780 Scanner Glass Replacement, Outer Shell Disassembly: 手順 1、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement, Outer Shell Disassembly: 手順 1、 2の画像 2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. HP Photosmart c4780 Scanner Glass Replacement: 手順 2、 1の画像 1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. HP Photosmart c4780 Scanner Glass Replacement: 手順 3、 1の画像 1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. HP Photosmart c4780 Scanner Glass Replacement: 手順 4、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement: 手順 4、 2の画像 2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. HP Photosmart c4780 Scanner Glass Replacement: 手順 5、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement: 手順 5、 2の画像 2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. HP Photosmart c4780 Scanner Glass Replacement: 手順 6、 1の画像 1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. HP Photosmart c4780 Scanner Glass Replacement: 手順 8、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement: 手順 8、 2の画像 2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. HP Photosmart c4780 Scanner Glass Replacement: 手順 9、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement: 手順 9、 2の画像 2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. HP Photosmart c4780 Scanner Glass Replacement: 手順 10、 1の画像 1
    • Pull the printer hood upward.
  10. HP Photosmart c4780 Scanner Glass Replacement, Scanner Glass: 手順 11、 1の画像 1
    • With the top half of the printer separated, lift the upper section with the scanner glass away from the lower section of the printer.
  11. HP Photosmart c4780 Scanner Glass Replacement: 手順 12、 2の画像 1 HP Photosmart c4780 Scanner Glass Replacement: 手順 12、 2の画像 2
    • With the glass facing upwards, remove the screw holding the glass in place.
  12. HP Photosmart c4780 Scanner Glass Replacement: 手順 13、 1の画像 1
    • Lift the glass up and away from the printer.
    • Handle glass with care.
    • Replace the broken glass piece with the replacement glass
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
garrett hall
メンバー登録日: 09/26/12
49 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S2G11
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 3,124
