必要な工具と部品
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Set aside the printer body
Unhook the encoding strip by pinching it on the right side and pulling away from the center of the ink cartridge track.
4 の人々がこのガイドを完成させました。
