メインコンテンツにスキップ
HP Photosmart c3180 Control Panel Circuitry Replacement
必要な工具と部品
  1. HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel of HP Photosmart c3180 printer: 手順 1、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement, Top Panel of HP Photosmart c3180 printer: 手順 1、 2の画像 2
    • Before disassembling your printer, be sure that the printer has been unplugged to avoid any risk of injury.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 2、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 2、 2の画像 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 3、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 3、 2の画像 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 4、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 4、 2の画像 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 5、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 5、 2の画像 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 6、 1の画像 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 7、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 7、 2の画像 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 8、 2の画像 1 HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 8、 2の画像 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 9、 1の画像 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. HP Photosmart c3180 Control Panel Circuitry Replacement, Control Panel Circuitry: 手順 10、 1の画像 1
    • Set aside the printer body.
    • Remove the three T10 12 mm Torx screws from the back of control panel circuit board.
  11. HP Photosmart c3180 Control Panel Circuitry Replacement: 手順 11、 1の画像 1
    • Using both hands, carefully lift the control panel circuit board from the top panel of the printer.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jim
メンバー登録日: 10/06/11
1,590 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S20G30
4 メンバー
25のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 4,411
