メインコンテンツにスキップ
HP Photosmart Premium C309g TouchSmart Display Screen Replacement
必要な工具と部品
  1. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement, TouchSmart Display Screen: 手順 1、 1の画像 1
    • Open the top of printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 2、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 2、 2の画像 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 3、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 3、 2の画像 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 4、 1の画像 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 5、 1の画像 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 6、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 6、 2の画像 2
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 7、 1の画像 1
    • Gently pull the display screen away from the printer.
    • Locate & unscrew the two 12mm screws using the T9 Torx Security screwdriver bit.
  8. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 8、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 8、 2の画像 2
    • Place thumb and forefinger where shown and pull this piece away from the printer.
    • Do not pull it away too hard. The piece is still connected by wiring ribbon.
  9. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 9、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 9、 2の画像 2
    • Pull both wiring ribbons out from the display screen piece. This will separate the piece from the printer.
    • Use tweezers if necessary.
  10. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 10、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 10、 2の画像 2
    • Push forward and down to release the retaining piece. This will detach the display screen from the front panel.
  11. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 11、 1の画像 1
    • Set the display screen face down.
    • Locate and unscrew all four 12mm screws on the back on the display screen using the T9 Torx Security screwdriver bit.
  12. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 12、 1の画像 1
    • Lift the back of the display screen to remove it.
  13. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 13、 2の画像 1 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: 手順 13、 2の画像 2
    • Place hands as shown and push with your thumbs to detach the plastic from the screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Laura
メンバー登録日: 10/23/14
694 ポイント
3のガイドは作成済み
チーム
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014人のメンバー
MTU-LAUER-F14S1G2
3 メンバー
5のガイドは作成済み
コメント 1 件
where can i get replacement part
fernando - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,178
