メインコンテンツにスキップ
HP Photosmart D110a Power Button Replacement
必要な工具と部品
  1. HP Photosmart D110a Power Button Replacement, Power Button: 手順 1、 1の画像 1
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: 手順 2、 1の画像 1
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 3
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: 手順 4、 1の画像 1
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: 手順 5、 1の画像 1
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 3
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 3
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
終わりに
ある他の人がこのガイドを完成しました。
作成者
12人の作成者と共同で作成されました。
Tim Wise
メンバー登録日: 04/01/11
173 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G38
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 3,600
