メインコンテンツにスキップ
はじめに
Replacing the ink cartridge is easy and requires no technical skill or tools.
Required Tools
  • None
  1. In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • In order to remove the old cartridge, open the mouth of the printer by pulling down on it.
    • There are two pieces to the mouth, make sure to pull down both.
  2. iPhoneのバッテリーキット
    Only $29.99
    Buy Now
    iPhoneのバッテリーキット
    Only $29.99
    Buy Now
  3. Press down on the head of the ink cartridge that needs replacing.  This will release the cartridge and allow you to pull it out. Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
    • Press down on the head of the ink cartridge that needs replacing. This will release the cartridge and allow you to pull it out.
    • Remember the orientation of the old cartridge. The new cartridge will be placed in the slot with the same orientation.
  4. Place the new cartridge into the slot and press firmly until it pops into place.
    • Place the new cartridge into the slot and press firmly until it pops into place.
まとめ
2 の人々がこのガイドを完成させました。
Tim Wise
メンバー登録日: 2011年04月01日
170 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G38
5 メンバー
10のガイドは作成済み
This DID NOT work. My fingers are are practically bleeding. Please please...there must be another way
April - 返信
the HP ink cartridge is 60. Does that make any difference???
April -
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 10,279
