メインコンテンツにスキップ
HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement
必要な工具と部品
  1. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Batteries: 手順 1、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Batteries: 手順 1、 2の画像 2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 3、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 3、 2の画像 2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 4、 1の画像 1
    • Pull out the batteries.
  4. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Plastic Casing: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 6、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 6、 2の画像 2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 7、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 7、 2の画像 2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 8、 3の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 8、 3の画像 2 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 8、 3の画像 3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 9、 1の画像 1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 10、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 10、 2の画像 2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
  10. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, LCD Screen: 手順 11、 1の画像 1
    • Orient the camera so that the LCD screen is facing you.
    • If case is still on, remove it by following the Plastic Casing Installation Guide found in the previous steps.
    • Removing the casing completely is crucial to completing this guide.
  11. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 12、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 12、 2の画像 2
    • Using a Phillips #00 remove the four 4.40 mm screws that secure the LCD screen to the frame.
  12. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 13、 1の画像 1
    • Allow the LCD screen to flip down. This will expose the electric strip that connects the screen to the camera.
  13. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 14、 1の画像 1
    • Look for where the yellow electric strip is attached to the camera. You will find a plastic grey bar and a white base holding this strip in place.
    • Push the grey bar away from the white base. This will release the yellow electric strip and free the LCD screen from the camera.
  14. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 15、 1の画像 1
    • Unplug the connected red and white wires. They will come out with the small white casing.
  15. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 16、 1の画像 1
    • Flip camera so that the lens is facing away from you. You should be looking at the LCD screen.
  16. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 17、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 17、 2の画像 2
    • Remove the bottom left LCD mounting frame screw. The screen should come loose after the screw is removed.
    • Remove the LCD screen from the camera. Make sure that the electric strip comes out with screen.
  17. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement, Viewfinder Mirror and Lens: 手順 18、 1の画像 1
    • Using a Phillips #00 screwdriver, remove the two screws securing the electric strip casing on the back of the camera.
  18. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 19、 1の画像 1
    • On the top of the camera where the shutter button is located, remove the screws located near the speaker that secure the electric strip casing.
  19. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 20、 1の画像 1
    この手順で使用する道具:
    購入する
    • Turn the camera over to the side that once housed the LCD screen. Locate the electric strip near the top of the camera.
    • Holding the camera securely, gently pull the end of the electric strip off of the back of the camera using a pair of tweezers.
  20. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 21、 1の画像 1
    • Ensure there are two ends of the electric strip detached from the camera.
  21. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 22、 1の画像 1
    • Using your fingers, fully detach the strip along with the casing. Be careful not to rip or tear any part of the electric strip.
    • Do not break or remove the black wire. This will damage the camera.
  22. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 23、 2の画像 1 HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 23、 2の画像 2
    • Orient the camera so that you are looking at the back of the camera. Directly above where the LCD screen was located, find the viewfinder cover clip.
    • Detach the clip with a pair of tweezers.
    • Push upwards and remove the viewfinder cover.
  23. HP Photosmart 935 Viewfinder Digital Camera Mirror and Lens Replacement: 手順 24、 1の画像 1
    • Remove the viewfinder mirror by pulling up n the mirror with tweezers.
終わりに
3 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Nick Oleskowicz
メンバー登録日: 04/03/12
287 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S15G13
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 31
今までの合計 3,247
