メインコンテンツにスキップ
HP Photosmart 935 Plastic Casing Replacement
必要な工具と部品
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: 手順 1、 2の画像 1 HP Photosmart 935 Plastic Casing Replacement, Batteries: 手順 1、 2の画像 2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: 手順 3、 2の画像 1 HP Photosmart 935 Plastic Casing Replacement: 手順 3、 2の画像 2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: 手順 4、 1の画像 1
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: 手順 5、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: 手順 6、 2の画像 1 HP Photosmart 935 Plastic Casing Replacement: 手順 6、 2の画像 2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: 手順 7、 2の画像 1 HP Photosmart 935 Plastic Casing Replacement: 手順 7、 2の画像 2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: 手順 8、 3の画像 1 HP Photosmart 935 Plastic Casing Replacement: 手順 8、 3の画像 2 HP Photosmart 935 Plastic Casing Replacement: 手順 8、 3の画像 3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: 手順 9、 1の画像 1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: 手順 10、 2の画像 1 HP Photosmart 935 Plastic Casing Replacement: 手順 10、 2の画像 2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
終わりに
作成者
9人の作成者と共同で作成されました。
Clay Young
メンバー登録日: 04/04/12
233 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S15G13
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,767
