メインコンテンツにスキップ
HP Pavillion dm4t-2100 Touchpad Replacement
必要な工具と部品
  1. HP Pavillion dm4t-2100 Touchpad Replacement, Battery: 手順 1、 2の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement, Battery: 手順 1、 2の画像 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 2、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 2、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 2、 3の画像 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Touchpad Replacement, Hard Drive: 手順 3、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement, Hard Drive: 手順 3、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement, Hard Drive: 手順 3、 3の画像 3
    • Position the computer so the front is towards you.
    • Remove two 5mm Phillips #1 screws
    • Slide the hard drive cover towards the empty battery spot and remove it.
  4. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 4、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 4、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 4、 3の画像 3
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  5. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 5、 1の画像 1
    • Disconnect the hard drive cable that is plugged in.
    • Lift the tab on the hard drive to pull it out of the computer.
    • Hard Drive is removed.
  6. HP Pavillion dm4t-2100 Touchpad Replacement, Touchpad: 手順 6、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement, Touchpad: 手順 6、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement, Touchpad: 手順 6、 3の画像 3
    • Remove one Phillips M2.5X5.0 Screw that is securing the optical drive.
    • With the nylon spudger, push the optical drive until you can grab it.
    • Pull the optical drive all the way out, until removed.
  7. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 7、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 7、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 7、 3の画像 3
    • Remove 2 Phillips M2.5X6.5 screws from the back of the computer.
    • Keyboard icons next to keyboard bolts
    • Turn the computer over, and open the computer as far as possible without breaking it.
    • Release the top of the keyboard by lifting up and gently pull the top up until the whole keyboard is up.
    • Lift plastic cover to release the ZIF connector that is holding the keyboard in place. Then remove the keyboard.
  8. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 8、 1の画像 1
    • Turn the computer upside down with the front towards you, and, remove the two rubber feet near the battery.
    • Organizing screws would be helpful
    • Remove 13 Phillips M2.0X7.0 screws.
    • Remove 6 Phillips M2.0X2.0 broad head screws.
    • Turn computer over and open the computer as far as possible without breaking it.
  9. HP Pavillion dm4t-2100 Touchpad Replacement: 手順 9、 3の画像 1 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 9、 3の画像 2 HP Pavillion dm4t-2100 Touchpad Replacement: 手順 9、 3の画像 3
    • Release 2 ZIF connectors where the touch pad cable and fingerprint reader are connected.
    • Remove 4 Phillips M2.0X4.0 screws near the top of the keyboard area.
    • Lift top cover from the base and release the ZIF connector that the power button is connected to. The cover should now be removed.
    • Using a nylon spudger could be helpful
    • Take the top cover and put it upside down and remove one Phillips M2.0X3.0 screw.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Brice Trupp
メンバー登録日: 01/06/16
133 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 7
今までの合計 311
