メインコンテンツにスキップ
HP Pavilion zv5000 Screen Replacement
必要な工具と部品
  1. HP Pavilion zv5000 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Screen Replacement: 手順 2、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 2、 2の画像 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Screen Replacement: 手順 3、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 3、 2の画像 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Screen Replacement, Keyboard: 手順 4、 2の画像 1 HP Pavilion zv5000 Screen Replacement, Keyboard: 手順 4、 2の画像 2
    • Using a Phillips #0 screwdriver, unscrew all four Phillips PM 2.5X13.0mm screws and place in a secure area until the end of the project.
  5. HP Pavilion zv5000 Screen Replacement: 手順 5、 1の画像 1
    • Flip laptop back over and open as far as it can go.
  6. HP Pavilion zv5000 Screen Replacement: 手順 6、 1の画像 1
    • Use the flat edge of the plastic spudger inserted under the bottom of the strip cover and pry upwards to un-clip the cover, starting at the right and moving to the left.
    • If the plastic spudger is not doing the trick, try using the metal spudger careful to not pop any keys out.
  7. HP Pavilion zv5000 Screen Replacement: 手順 7、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 7、 2の画像 2
    • Use hands to completely lift off the strip cover and remove.
  8. HP Pavilion zv5000 Screen Replacement: 手順 8、 1の画像 1
    • Use the Phillips #0 screwdriver again, unscrew all four Phillips PM 2.5X13.0mm screws from the top of the keyboard and set aside.
  9. HP Pavilion zv5000 Screen Replacement: 手順 9、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 9、 2の画像 2
    • Using your hands, lift the keyboard up from the top towards yourself until the keyboard is resting in your hand.
    • Do not aggressively pull at the keyboard for risk of ripping the connector cable.
  10. HP Pavilion zv5000 Screen Replacement: 手順 10、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 10、 2の画像 2
    • Gently slide out the connecting cable from the laptop to the keyboard.
    • Do not aggressively pull at the connecting cable.
  11. HP Pavilion zv5000 Screen Replacement: 手順 11、 1の画像 1
    • Completely remove the keyboard from the rest of the laptop.
  12. HP Pavilion zv5000 Screen Replacement, Screen: 手順 12、 1の画像 1
    • Flip the Pavilion back over on its backside.
  13. HP Pavilion zv5000 Screen Replacement: 手順 13、 3の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 13、 3の画像 2 HP Pavilion zv5000 Screen Replacement: 手順 13、 3の画像 3
    • Using the same Phillips #0 screwdriver, unscrew the six Phillips PM 2.5X6.0mm screws.
    • Also remove the four Phillips PM 2.5X13.0mm screws to remove the thermal plate with the same screwdriver.
  14. HP Pavilion zv5000 Screen Replacement: 手順 14、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 14、 2の画像 2
    この手順で使用する道具:
    購入する
    • Flip the laptop back over and open the lid all the way.
    • Using the flat edge of the plastic spudger, pry straight up to remove the Mini PCI Connector Cables from the board.
    • Tweezers can also be used to gently squeeze and pull up on the Mini PCI Cable Connectors to remove from the board.
    • When reinstalling, place the Mini PCI Connector Cables back in place and gently press straight down until they snap into place.
  15. HP Pavilion zv5000 Screen Replacement: 手順 15、 3の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 15、 3の画像 2 HP Pavilion zv5000 Screen Replacement: 手順 15、 3の画像 3
    • Using the tweezers, gently squeeze and pull backwards on the display cable until it is disconnected.
    • To reinsert, simply align the display cable to its proper spot and gently push into place.
  16. HP Pavilion zv5000 Screen Replacement: 手順 16、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 16、 2の画像 2
    • Use the Phillips #0 screwdriver again to remove the four Phillips 2.5X13.0mm screws that hold the clips for the screen into place.
  17. HP Pavilion zv5000 Screen Replacement: 手順 17、 2の画像 1 HP Pavilion zv5000 Screen Replacement: 手順 17、 2の画像 2
    • Turn the laptop around until the top cover is facing you. Keep the laptop in an open position.
    • Unscrew the four Phillips PM 2.5X6.0mm screws using the Phillips #0 that hold the clips of the screen on to the base.
  18. HP Pavilion zv5000 Screen Replacement: 手順 18、 1の画像 1
    • Firmly grasp the top of the screen with your hands and pull towards you and upwards to remove the screen from the base.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Eliza Marks
メンバー登録日: 10/18/16
649 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-6, Catania Fall 2016 UMass Dartmouth, Team 4-6, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S4G6
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 1,179
