このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Rotate it so the display is on your right and the keyboard is on your left.
Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
The switch cover should easily separate from the laptop as you run the spudger through.
この手順は未翻訳です。 翻訳を手伝う。
Find the ribbon cable on the LED board located at the top of the laptop.
You will notice that the ribbon cable is connected to two levels - you will be dealing with the one on the lower level.
Find the black latch at the end of the ribbon cable and unlatch it with a spudger to release it.
2 の人々がこのガイドを完成させました。
