この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
You'll need to remove the switch cover to reach the motherboard.
必要な工具と部品
Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
Lift the cover from the right to remove it.
Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
ある他の人がこのガイドを完成しました。
