はじめに
You'll need to remove the switch cover to reach the motherboard.
パーツ
パーツは指定されていません。
Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
Lift the cover from the right to remove it.
Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
ある他の人がこのガイドを完成しました。
