メインコンテンツにスキップ
HP Pavilion x360 m3-u103dx RAM Replacement
必要な工具と部品
  1. HP Pavilion x360 m3-u103dx RAM Replacement, Keyboard: 手順 1、 1の画像 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 2、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 2、 2の画像 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 3、 1の画像 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 4、 1の画像 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 5、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 5、 2の画像 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 6、 1の画像 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 8、 1の画像 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u103dx RAM Replacement, Battery: 手順 9、 1の画像 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 10、 1の画像 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: 手順 11、 3の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: 手順 11、 3の画像 2 HP Pavilion x360 m3-u103dx RAM Replacement, USB Port Shield: 手順 11、 3の画像 3
    • (You don't NEED to remove this shielding as you can remove the board with it still there.)
    • Remove the adhesive strip.
    • Lift the shield away from the base of the laptop.
  12. HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): 手順 12、 3の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): 手順 12、 3の画像 2 HP Pavilion x360 m3-u103dx RAM Replacement, System Board (Motherboard): 手順 12、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Disconnect the ribbon cables attached to the system board (motherboard).
    • Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  13. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 13、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 13、 2の画像 2
    • Disconnect the fastened cables from the system board (motherboard) by carefully pushing the cable's plastic edges using the Heavy Duty Spudger.
  14. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 14、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 14、 2の画像 2
    • Pull the clipped cables from system board (motherboard).
  15. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 15、 3の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 15、 3の画像 2 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 15、 3の画像 3
    • Remove the system board (motherboard).
    • Using the Phillips 00 Screw Driver, remove 9 Phillips 2.0 x 4.7 mm screws with "M2L4" next to them.
    • Using the Phillips 00 Screw Driver, remove the silver screw.
  16. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 16、 1の画像 1
    • Carefully lift the front side of the system board (motherboard).
  17. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 17、 1の画像 1
    • Using a Heavy Duty Spudger, disconnect the black and red RTC battery cable on the left side of the system board (motherboard).
  18. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 18、 1の画像 1
    • Release the system board (motherboard) from the base enclosure.
    • Place the motherboard somewhere safe since it is the most delicate and expensive part of the laptop.
  19. HP Pavilion x360 m3-u103dx RAM Replacement, RAM: 手順 19、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement, RAM: 手順 19、 2の画像 2
    • Gently pry off the metal container holding the RAM.
  20. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 20、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 20、 2の画像 2
    • Push both tabs outward, so that the RAM pops up.
  21. HP Pavilion x360 m3-u103dx RAM Replacement: 手順 21、 2の画像 1 HP Pavilion x360 m3-u103dx RAM Replacement: 手順 21、 2の画像 2
    • Gently lift the RAM out of the socket, retaining the 30 degree angle it rests at.
終わりに
作成者
1人の作成者と共同作成されました。
Victor Samuel
メンバー登録日: 01/08/15
220 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S2-G2, Wilson Summer 2019 IUPUI, Team S2-G2, Wilson Summer 2019人のメンバー
IUPUI-WILSON-SU19S2G2
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 21
今までの合計 2,673
