メインコンテンツにスキップ
HP Pavilion x360 m3-u101dx RAM Replacement
必要な工具と部品
  1. HP Pavilion x360 m3-u101dx RAM Replacement, Keyboard Panel: 手順 1、 1の画像 1
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 2、 1の画像 1
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 3、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 3、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 3、 3の画像 3
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 4、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 4、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 4、 3の画像 3
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 5、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 5、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 5、 3の画像 3
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
  6. HP Pavilion x360 m3-u101dx RAM Replacement, Motherboard: 手順 6、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement, Motherboard: 手順 6、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement, Motherboard: 手順 6、 3の画像 3
    • The component that you MUST disconnect first is the battery to prevent any power that might be stored in the the computer even if it is shutdown.
    • Use a plastic opening tool to lift the battery cable out from the motherboard.
    • Disconnect the seven ribbon cables connected to the motherboard using a finger or plastic opening tool.
    • You can work from left to right from the battery to ensure no cables are missed.
  7. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 7、 1の画像 1
    • Remove the ten 1.2mm Phillips #1 screws that hold the motherboard into the frame of the laptop.
  8. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 8、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 8、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 8、 3の画像 3
    • Remove the motherboard by lifting it up and pulling it out.
    • DO NOT force it out if the motherboard appears to be stuck. Track back and see what is preventing the motherboard from being removed (i.e. cable or screw) to prevent any damage to other components.
  9. HP Pavilion x360 m3-u101dx RAM Replacement, RAM: 手順 9、 2の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement, RAM: 手順 9、 2の画像 2
    • Use an iFixit opening tool to snap the silver the case off of the motherboard.
  10. HP Pavilion x360 m3-u101dx RAM Replacement: 手順 10、 3の画像 1 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 10、 3の画像 2 HP Pavilion x360 m3-u101dx RAM Replacement: 手順 10、 3の画像 3
    • Push down on the metal locks on each side of the RAM to pop the sticks out.
    • Make sure to move the metal locks aside before you push the RAM back in place.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Adrse Fazelyar
メンバー登録日: 01/22/20
285 ポイント
2のガイドは作成済み
チーム
York University, Team S8-G1, Turner Winter 2020 York University, Team S8-G1, Turner Winter 2020人のメンバー
YORK-TURNER-W20S8G1
5 メンバー
7のガイドは作成済み
コメント 1 件
Where can I buy this motherboard?
Sheriff Azeez - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 766
