メインコンテンツにスキップ
HP Pavilion x360 m3-u101dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion x360 m3-u101dx Hard Drive Replacement, Keyboard Panel: 手順 1、 1の画像 1
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 2、 1の画像 1
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 3、 3の画像 1 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 3、 3の画像 2 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 3、 3の画像 3
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 4、 3の画像 1 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 4、 3の画像 2 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 4、 3の画像 3
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 5、 3の画像 1 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 5、 3の画像 2 HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 5、 3の画像 3
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
  6. HP Pavilion x360 m3-u101dx Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Remove the four 3.7mm Phillips #1 screws holding the hard drive in place.
    • Remove the SATA cable from the motherboard.
  7. HP Pavilion x360 m3-u101dx Hard Drive Replacement: 手順 7、 1の画像 1
    • Unplug the SATA cable from the hard drive.
    • Gently remove the hard drive from the computer case.
終わりに
作成者
2人の作成者と共同で作成されました。
Tyler Padutsch
メンバー登録日: 01/22/20
178 ポイント
2のガイドは作成済み
チーム
York University, Team S8-G1, Turner Winter 2020 York University, Team S8-G1, Turner Winter 2020人のメンバー
YORK-TURNER-W20S8G1
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 1,659
