メインコンテンツにスキップ
HP Pavilion x360 m3-u101dx Battery Replacement
必要な工具と部品
  1. HP Pavilion x360 m3-u101dx Battery Replacement, Keyboard Panel: 手順 1、 1の画像 1
    • Flip the laptop over so that the bottom of the laptop is facing up.
  2. HP Pavilion x360 m3-u101dx Battery Replacement: 手順 2、 1の画像 1
    • Remove five 1.4mm Phillips #1 screws from the bottom of the laptop.
  3. HP Pavilion x360 m3-u101dx Battery Replacement: 手順 3、 3の画像 1 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 3、 3の画像 2 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 3、 3の画像 3
    • Remove the rubber grip using a plastic opening tool.
    • Remove five 1.7mm Phillips #1 screws.
  4. HP Pavilion x360 m3-u101dx Battery Replacement: 手順 4、 3の画像 1 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 4、 3の画像 2 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 4、 3の画像 3
    • Lift open the laptop screen and flip it around so that the keyboard is facing up.
    • Insert a plastic opening tool into one of the corners to create a gap between the bottom panel and the keyboard panel.
    • Guide the plastic opening tool around the perimeter of the panel to detach all the clips that are supporting it in place.
    • Do not pull the panel off by one corner as it can cause damage to the plastic.
    • Detach the keyboard panel from the frame.
    • There are two ribbon cables attached to the keyboard and trackpad so do not pull the keyboard panel away until you disconnect these ribbons in the next step.
  5. HP Pavilion x360 m3-u101dx Battery Replacement: 手順 5、 3の画像 1 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 5、 3の画像 2 HP Pavilion x360 m3-u101dx Battery Replacement: 手順 5、 3の画像 3
    • Remove the two ribbon cables connected to the inside of the laptop by using a finger to lift up on the latches.
    • Remove the keyboard panel from the rest of the laptop.
  6. HP Pavilion x360 m3-u101dx Battery Replacement, Battery: 手順 6、 1の画像 1
    • Remove the six 4.6mm Phillips #1 screws from the edges of the battery.
    • This device is missing the battery.
  7. HP Pavilion x360 m3-u101dx Battery Replacement: 手順 7、 1の画像 1
    • Gently lift the battery and bring downward away from its port to remove it from the laptop.
終わりに
作成者
1人の作成者と共同作成されました。
Tyler Padutsch
メンバー登録日: 01/22/20
178 ポイント
2のガイドは作成済み
チーム
York University, Team S8-G1, Turner Winter 2020 York University, Team S8-G1, Turner Winter 2020人のメンバー
YORK-TURNER-W20S8G1
5 メンバー
7のガイドは作成済み
コメント 1 件
I replaced the battery now the screen doesn't turn on. I plugged it into an external monitor and the computer works fine and even the touch aspect of the screen works, but it stays black. Did i accidentally disconnect something?
G Bates - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 21
今までの合計 955
