メインコンテンツにスキップ
HP Pavilion x360 m3-u001dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Keyboard: 手順 1、 1の画像 1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 2、 2の画像 2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 3、 1の画像 1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 4、 1の画像 1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 5、 2の画像 1 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 5、 2の画像 2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 6、 1の画像 1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 7、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 8、 1の画像 1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Battery: 手順 9、 1の画像 1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 10、 1の画像 1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u001dx Hard Drive Replacement, Hard Drive: 手順 11、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Disconnect the ribbon cables attaching the hard drive to the system board (motherboard).
    • Use the purple plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  12. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 12、 2の画像 1 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 12、 2の画像 2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 2.0 x 4.6 mm screws around the perimeter of the hard drive.
  13. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 13、 1の画像 1
    • Using the tab provided, lift and remove the hard drive out of the laptop base.
  14. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 14、 2の画像 1 HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 14、 2の画像 2
    • Using the Phillips00 Screw Driver, remove 4 Phillips 3.0 x 3.7 mm screws on exterior mounting bracket.
    • There are 2 Phillips screws on each side of the hard drive bracket.
  15. HP Pavilion x360 m3-u001dx Hard Drive Replacement: 手順 15、 1の画像 1
    • Remove the mounting bracket.
終わりに
Follow these instructions in reverse order to reassemble your device.
9 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Subhleen
メンバー登録日: 02/01/17
1,268 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team 1-6, Rose Winter 2017 UW Tacoma, Team 1-6, Rose Winter 2017人のメンバー
UWT-ROSE-W17S1G6
4 メンバー
8のガイドは作成済み
8 件のコメント
Awesome. Thanks. This helped me a lot.
Gouse Khan - 返信
Can anyone tell me the model number of the hdd ribbon cable please :)
James Harris - 返信
I need to replace the data ribbon as well.
KurwynK -
Found it. part# 856011–001
KurwynK - 返信
My HP Pavilion X360 M3-u00ldx is not recognizing my brand new Samsung 860 Evo 500GB ssd. Upon start up I get  3F0 error which states there is no hard drive. When I boot to a Windows 10 disc it also doesn't recognize it.
Any suggestions on how it can be recognized is appreciated.
Thank you for looking.
downdog89 - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 22
過去 30 日: 68
今までの合計 22,378
