メインコンテンツにスキップ
HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement
必要な工具と部品
  1. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Keyboard: 手順 1、 1の画像 1
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 2、 1の画像 1
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 3、 1の画像 1
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 4、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 4、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 4、 3の画像 3
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 5、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 5、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 6、 2の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 6、 2の画像 2
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 7、 2の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 7、 2の画像 2
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: 手順 8、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: 手順 8、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, Battery: 手順 8、 3の画像 3
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 9、 2の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 9、 2の画像 2
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
  10. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): 手順 10、 2の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement, System Board (Motherboard): 手順 10、 2の画像 2
    • Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
    • 8 Phillips 2.0 x 4.7 mm screws.
  11. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 11、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 11、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 11、 3の画像 3
    • Disconnect the 3 bundle cable connectors by gently gripping the cable wires and pulling outwards.
    • Be sure to grip each of the cables equally so no single cable is overly strained.
  12. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 12、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 12、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 12、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    購入する
    • Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
    • Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  13. HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 13、 3の画像 1 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 13、 3の画像 2 HP Pavilion x360 m1-u001dx System Board (Motherboard) Replacement: 手順 13、 3の画像 3
    • Gently lift up the motherboard to disconnect it from the computer.
終わりに
作成者
2人の作成者と共同で作成されました。
Katie
メンバー登録日: 09/21/17
549 ポイント
5のガイドは作成済み
チーム
Idaho State University, Team S4-G5, Watkins Fall 2017 Idaho State University, Team S4-G5, Watkins Fall 2017人のメンバー
ISU-WATKINS-F17S4G5
4 メンバー
5のガイドは作成済み
コメント 1 件
where can I get this mother board from
Kevin Juma - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 2,237
