はじめに
If keys are malfunctioning (sticking or not registering), this guide will explain how to replace your keyboard. To replace your keyboard, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
必要な工具と部品
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
ある他の人がこのガイドを完成しました。
