メインコンテンツにスキップ
HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement
必要な工具と部品
  1. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: 手順 1、 3の画像 1 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: 手順 1、 3の画像 2 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement, RAM: 手順 1、 3の画像 3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 2、 3の画像 1 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 2、 3の画像 2 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 2、 3の画像 3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 3、 3の画像 1 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 3、 3の画像 2 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 3、 3の画像 3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 4、 2の画像 1 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 4、 2の画像 2
    • Pinch and lift the black and gray plate labeled with "WLAN."
  5. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 5、 1の画像 1
    • Use the spudger to unhook the locks on each side of the green RAM stick.
    • The locks will be unhooked by pushing them gently away from the RAM sticks.
  6. HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 6、 2の画像 1 HP Pavilion x360 Convertible 14-dw1025nr RAM Replacement: 手順 6、 2の画像 2
    • Gently pull the RAM stick up and out to remove.
    • Repeat the previous two steps to remove the second RAM strip.
終わりに
作成者
4人の作成者と共同で作成されました。
Amber Norton
メンバー登録日: 09/14/22
661 ポイント
4のガイドは作成済み
チーム
Western Carolina University, Team 1-3, Virtue Fall 2022 Western Carolina University, Team 1-3, Virtue Fall 2022人のメンバー
WCU-VIRTUE-F22S1G3
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 21
今までの合計 313
