メインコンテンツにスキップ
HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement
必要な工具と部品
  1. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 手順 1、 3の画像 1 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 手順 1、 3の画像 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Keyboard Panel: 手順 1、 3の画像 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 2、 3の画像 1 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 2、 3の画像 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 2、 3の画像 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 手順 3、 3の画像 1 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 手順 3、 3の画像 2 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement, Fan and Heatsink Assembly: 手順 3、 3の画像 3
    • Remove all three 3.5 mm screws using the Phillips #0 screwdriver.
    • Disconnect the cables above the fan.
    • Disconnect the wire next to the fan.
  4. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 4、 1の画像 1
    • Remove nine 4mm screws using the Phillips #0 screwdriver.
  5. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 5、 1の画像 1
    • Flip over the motherboard.
  6. HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 6、 2の画像 1 HP Pavilion x360 15t-br000 Fan and Heatsink Assembly Replacement: 手順 6、 2の画像 2
    • Remove four 3.5mm screws using the Phillips #0 screwdriver.
    • Remove the fan and heatsink assembly from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
xi yang
メンバー登録日: 10/01/19
403 ポイント
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 517
