メインコンテンツにスキップ
HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement
必要な工具と部品
  1. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Back Cover: 手順 1、 1の画像 1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 2、 1の画像 1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 3、 2の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 3、 2の画像 2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 4、 2の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 4、 2の画像 2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 5、 3の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 5、 3の画像 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 5、 3の画像 3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 手順 6、 3の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 手順 6、 3の画像 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Battery: 手順 6、 3の画像 3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 7、 2の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 7、 2の画像 2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement, Heat Sink and Fan: 手順 8、 1の画像 1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 9、 2の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    購入する
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 10、 3の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 10、 3の画像 2 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 10、 3の画像 3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 11、 2の画像 1 HP Pavilion x360 14m-cd0005dx Heat Sink and Fan Replacement: 手順 11、 2の画像 2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jacob Richardson Earl
メンバー登録日: 01/14/20
966 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 506
