はじめに
This guide will help you replace the speakers in your HP Pavilion x360 14m-ba114dx laptop. The speakers are responsible for taking electronic signals from the computer and turning them into audible noise. If your laptop will not produce any sound or if the sound it produces is muffled, garbled, or distorted, there may be a problem with your laptop’s speakers. Please visit this troubleshooting page for possible solutions to the problem. If none of these solutions work, use this guide to replace the speakers.
A prerequisite to replacing the speakers is to remove the laptop’s battery. If you notice once the laptop is open that the battery is swollen, remove it with caution. If swollen, do not charge the battery, keep the battery at a stable room temperature, and dispose of it properly at a recycling center. This page will help you deal with a swollen battery.
Also, make sure that you unplug your device from any external power sources and completely power it off before beginning this replacement.
必要な工具と部品
Using a #0 Phillips-head screwdriver, remove the three 5 mm screws along the bottom of the back cover.
Using a #0 Phillips-head screwdriver, remove the 6 mm screw at the top of the back cover.
Using the curved end of the Halberd Spudger, disconnect the Speaker Cable from the port that connects it to the motherboard. To complete this step, use the curved end of the spudger to pry the plug out of the port.
Using the plastic Spudger, remove the touch screen ZIF connector by popping the cap up on top of the connector and sliding it out of its slot.
Move the wire away from the connection point to disconnect the touch screen cable from the motherboard.
Pull the wire out from its track next to the speaker.
この手順で使用する道具:Tweezers$4.99
Use the Blunt Tweezers to disconnect the Wireless Card Antenna Cables. Start with the cable labeled M2, which is connected to Port #2. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Use the Blunt Tweezers to disconnect the Antenna Cable labeled A1, which is connected to Port #1. To disconnect he cable, grab it on both sides with the tweezers and pull up.
Using the Blunt Tweezers, unwind the cables from the track to the right of the speaker. The cables are held in place by two black hooks.
