メインコンテンツにスキップ
HP Pavilion x360 14m-ba011dx RAM Replacement
必要な工具と部品
  1. HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: 手順 1、 2の画像 1 HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: 手順 1、 2の画像 2
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 2、 1の画像 1
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 3、 2の画像 1 HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 3、 2の画像 2
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 4、 2の画像 1 HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 4、 2の画像 2
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 5、 1の画像 1
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: 手順 6、 2の画像 1 HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: 手順 6、 2の画像 2
    • Unclip the 5 cables connecting the motherboard to the computer.
  7. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 7、 1の画像 1
    • Remove ten 4 mm screws using a Phillips #00 screwdriver.
  8. HP Pavilion x360 14m-ba011dx RAM Replacement: 手順 8、 1の画像 1
    • Gently remove the motherboard.
  9. HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: 手順 9、 2の画像 1 HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: 手順 9、 2の画像 2
    この手順で使用する道具:
    • Flip the motherboard upside down and remove the silver box covering the RAM sticks.
    • Using your fingers or a pair of tweezers, pull the edges of the card to the side and lift the RAM out of the motherboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Katie Pruis
メンバー登録日: 01/16/20
820 ポイント
5のガイドは作成済み
チーム
コメント 1 件
Don't forget the WIFI chip in step 7, take out the silver screw first before taking off the motherboard.
Jerri - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 36
今までの合計 3,466
