メインコンテンツにスキップ
HP Pavilion x2 10-n113dx Hinge Replacement
必要な工具と部品
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 手順 1、 2の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 手順 1、 2の画像 2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 2、 2の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 3、 1の画像 1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 4、 2の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 4、 2の画像 2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 5、 3の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 5、 3の画像 2 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 5、 3の画像 3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 6、 2の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 6、 2の画像 2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 7、 1の画像 1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 8、 1の画像 1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 9、 3の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 9、 3の画像 2 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 9、 3の画像 3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: 手順 10、 3の画像 1 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 10、 3の画像 2 HP Pavilion x2 10-n113dx Hinge Replacement: 手順 10、 3の画像 3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
終わりに
作成者
3人の作成者と共同で作成されました。
Ajay Panuganti
メンバー登録日: 04/01/19
181 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019人のメンバー
IUPUI-HARLEY-S19S1G4
3 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 1,146
