Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
Disconnect the wire from the system board using the plastic opening tool.
Disconnect the wire from the optical drive using the plastic opening tool.
Gently lift the top cover from the tablet.
Using the plastic opening tool, disconnect the plastic blue film from the tablet.
Disconnect the wire using the plastic opening tool.
Using a Phillips #00, remove the 4.5 mm screws that connect the fan to the board.
Using a plastic opening tool, disconnect the wire that attached the fan to the board.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
