メインコンテンツにスキップ
HP Pavilion p6 Wireless Card Replacement
必要な工具と部品
  1. HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 手順 1、 3の画像 1 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 手順 1、 3の画像 2 HP Pavilion p6 Wireless Card Replacement, Side Panel Removal: 手順 1、 3の画像 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recomended to wait at least 15 minutes after turning it off to allow the computer and internal components to cool down.
    • It is recomended to lay the computer down with the pull tab at the top to allow it to be easily opened.
    • It is also worth mentioning at this point that for complete safety when working inside the computer that wearing an anti-static band and touching a grounded metal object before starting is good practice.
  2. HP Pavilion p6 Wireless Card Replacement: 手順 2、 3の画像 1 HP Pavilion p6 Wireless Card Replacement: 手順 2、 3の画像 2 HP Pavilion p6 Wireless Card Replacement: 手順 2、 3の画像 3
    • In order to remove the side panel a single screw needs to first be removed.
    • The side panel can then be pulled towards the back of the computer using the pull tab provided.
    • The panel then needs to be rotated as showen in order to remove it from the computer.
  3. HP Pavilion p6 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 1 HP Pavilion p6 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 2 HP Pavilion p6 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 3
    • First locate the wireless card, it should look like this.
    • Next using a spudger or equivalent carefully pry the antenna cable off the wireless card, it should now look like the second picture.
    • A single screw then needs to be removed in order to free the card.
  4. HP Pavilion p6 Wireless Card Replacement: 手順 4、 2の画像 1 HP Pavilion p6 Wireless Card Replacement: 手順 4、 2の画像 2
    • The card can then just be easily removed by pulling it out and up.
    • The wireless card should then be kept in a safe place and care taken not to lose the small screw that goes with it.
終わりに
8 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Oli
メンバー登録日: 01/03/14
1,442 ポイント
4のガイドは作成済み
2 件のコメント
Thx this helped a lot with my pc
Nathan Moore - 返信
Also will the card still work without the antenna cable?
Nathan Moore - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 25
今までの合計 2,963
