メインコンテンツにスキップ
HP Pavilion g7-2275dx Wireless Card Replacement
必要な工具と部品
  1. HP Pavilion g7-2275dx Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Wireless Card Replacement: 手順 2、 1の画像 1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
  3. HP Pavilion g7-2275dx Wireless Card Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: 手順 3、 1の画像 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  4. HP Pavilion g7-2275dx Wireless Card Replacement: 手順 4、 2の画像 1 HP Pavilion g7-2275dx Wireless Card Replacement: 手順 4、 2の画像 2
    • Slide the back panel down and pull it up.
  5. HP Pavilion g7-2275dx Wireless Card Replacement, Wireless Card: 手順 5、 1の画像 1
    • Use a Phillips #1 screw driver to unscrew the black 4 mm Phillips #1 screw on the wireless card.
  6. HP Pavilion g7-2275dx Wireless Card Replacement: 手順 6、 2の画像 1 HP Pavilion g7-2275dx Wireless Card Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to lift the wireless card out of its slot.
  7. HP Pavilion g7-2275dx Wireless Card Replacement: 手順 7、 2の画像 1 HP Pavilion g7-2275dx Wireless Card Replacement: 手順 7、 2の画像 2
    • Pull the black and white wires up and off of the wireless card.
    • Remove the wireless card.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
John Sutton
メンバー登録日: 04/24/14
1,566 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G51
4 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 2,221
