メインコンテンツにスキップ
HP Pavilion g7-2275dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion g7-2275dx Hard Drive Replacement, Disassembling HP Pavilion g7-2275dx Back Panel: 手順 1、 1の画像 1
    • Unscrew one Phillips #1 screw from the back panel.
    • The screw is on a spring and attached to the panel. It will pop up, but will not separate from the back panel.
  2. HP Pavilion g7-2275dx Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion g7-2275dx Hard Drive Replacement: 手順 2、 2の画像 2
    • Slide the back panel down and pull it up.
  3. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 1 HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 2
    • Static electricity can damage the components of your laptop. Make sure you are wearing an anti-static bracelet before you touch the hard drive.
    • Using the black tab on the connect and/or a prying tool, lift up to disconnect the black hard drive cable from the green circuit board.
    • Pull the black cable up and out of the back panel. This will make taking the hard drive out much easier.
  4. HP Pavilion g7-2275dx Hard Drive Replacement: 手順 4、 2の画像 1 HP Pavilion g7-2275dx Hard Drive Replacement: 手順 4、 2の画像 2
    • Gently pull up on the plastic tab attached to the hard drive.
    • Pull the hard drive up and to the right to remove it completely from the laptop.
  5. HP Pavilion g7-2275dx Hard Drive Replacement, Hard Drive: 手順 5、 1の画像 1
    • Remove the black SATA cable from the hard drive.
  6. HP Pavilion g7-2275dx Hard Drive Replacement: 手順 6、 2の画像 1 HP Pavilion g7-2275dx Hard Drive Replacement: 手順 6、 2の画像 2
    • Remove the black rubber end caps.
  7. HP Pavilion g7-2275dx Hard Drive Replacement: 手順 7、 2の画像 1 HP Pavilion g7-2275dx Hard Drive Replacement: 手順 7、 2の画像 2
    • Remove the four silver 5 mm Phillips #1 screws from the hard drive.
  8. HP Pavilion g7-2275dx Hard Drive Replacement: 手順 8、 1の画像 1
    • Remove the plastic cover from the hard drive.
終わりに
To reassemble or replace your hard drive, follow these instructions in reverse order with the working drive.
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Erik Miller
メンバー登録日: 04/22/14
2,123 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G51
4 メンバー
21のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 4,980
