メインコンテンツにスキップ
HP Pavilion g7-2023cl Keyboard Replacement
必要な工具と部品
  1. HP Pavilion g7-2023cl Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Keyboard Replacement: 手順 2、 3の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 2、 3の画像 2 HP Pavilion g7-2023cl Keyboard Replacement: 手順 2、 3の画像 3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Keyboard Replacement, Service Door: 手順 3、 2の画像 1 HP Pavilion g7-2023cl Keyboard Replacement, Service Door: 手順 3、 2の画像 2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Keyboard Replacement: 手順 4、 2の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 4、 2の画像 2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 手順 5、 3の画像 1 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 手順 5、 3の画像 2 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 手順 5、 3の画像 3
    • Locate the screw that secures the keyboard.
    • It is near the RAM module and the screw hole is identified by a keyboard symbol with the text underneath it that reads M2.5×6.5.
  6. HP Pavilion g7-2023cl Keyboard Replacement: 手順 6、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
  7. HP Pavilion g7-2023cl Keyboard Replacement: 手順 7、 2の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 7、 2の画像 2
    • Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
    • The release holes are on the base enclosure identified by a keyboard symbol with the word "release" written next to it.
  8. HP Pavilion g7-2023cl Keyboard Replacement: 手順 8、 1の画像 1
    • Turn the device over and open the laptop.
  9. HP Pavilion g7-2023cl Keyboard Replacement: 手順 9、 2の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 9、 2の画像 2
    • Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
    • Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
  10. HP Pavilion g7-2023cl Keyboard Replacement: 手順 10、 3の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 10、 3の画像 2 HP Pavilion g7-2023cl Keyboard Replacement: 手順 10、 3の画像 3
    • Locate the keyboard cable connector.
    • Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
  11. HP Pavilion g7-2023cl Keyboard Replacement: 手順 11、 2の画像 1 HP Pavilion g7-2023cl Keyboard Replacement: 手順 11、 2の画像 2
    • Pull the keyboard ribbon cable out from the connector.
  12. HP Pavilion g7-2023cl Keyboard Replacement: 手順 12、 1の画像 1
    • Remove the keyboard from the device.
終わりに
作成者
1人の作成者と共同作成されました。
Thomas Maloney
メンバー登録日: 03/21/19
1,060 ポイント
9のガイドは作成済み
チーム
UMass Dartmouth, Team S8-G4, Bailey Spring 2019 UMass Dartmouth, Team S8-G4, Bailey Spring 2019人のメンバー
UMASSD-BAILEY-S19S8G4
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 295
