はじめに
This guide will show you how to switch out the battery for the HP Pavilion g7-1368x. Before beginning, make sure to completely power down the device. This process will take less than 5 minutes with a new battery. No tools are required for this replacement.
必要な工具と部品
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
ある他の人がこのガイドを完成しました。
