はじめに
This guide will show you how to replace the HP Pavilion g7-1368 hard drive. This process should take approximately 10 minutes using only a Phillips #1 screwdriver. Make sure to shut down the device before proceeding with the replacement.
必要な工具と部品
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
