はじめに
This guide will provide instructions on how to remove and replace a hard drive in an HP Pavilion g7-1365dx. Use this guide when having issues with a hard drive that is faulty.
必要な工具と部品
Flip the laptop so that it is upside down and opens away from you. This exposes the battery, it will be centered at the bottom of the laptop .
Push the switch above the battery towards the center of the laptop .
Using a Phillips size 0 screwdriver, unscrew the 2 Phillips screws.
Use the opening tool around the edges of the service door to loosen it and remove it.
Disconnect the drive connector cable from the system board by pulling the plastic tab on top of the connector.
Use the opening tool to lift the hard drive out.
Remove the hard drive.
