メインコンテンツにスキップ
HP Pavilion g6-1b79dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion g6-1b79dx Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 2、 2の画像 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 3、 2の画像 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx Hard Drive Replacement, Bottom Panel: 手順 4、 1の画像 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 5、 1の画像 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 6、 3の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 6、 3の画像 2 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 6、 3の画像 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx Hard Drive Replacement, CD Drive: 手順 7、 2の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement, CD Drive: 手順 7、 2の画像 2
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  8. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 8、 3の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 8、 3の画像 2 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 8、 3の画像 3
    • Slide the CD drive out from the exterior of the laptop.
  9. HP Pavilion g6-1b79dx Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement, Hard Drive: 手順 9、 2の画像 2
    • Use the PH 00 screwdriver to unscrew the 2.5 mm screw to the right of the hard drive.
  10. HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 10、 3の画像 1 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 10、 3の画像 2 HP Pavilion g6-1b79dx Hard Drive Replacement: 手順 10、 3の画像 3
    • Pull the triangular blue tab to diconnect and remove the hard drive. You can see the word 'Pull' on the cover.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
patrickhall
メンバー登録日: 09/23/15
730 ポイント
3のガイドは作成済み
チーム
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S10G12
3 メンバー
8のガイドは作成済み
コメント 1 件
I used my (brand new!) Pro Tech toolkit to work through these instructions. Everything was pretty much as advertised except that my Pavilion g series is apparently older than the displayed model. Specifically, there was no screw to the right of the drive, and the drive is completely encased in a rubber harness that is used to friction seat the drive, and the area where the pull tab would be is covered by a plastic shield that appears to be made of same electrostatic material as antistatic bags. Solution was simply to used standard spudger to lift rear of drive against friction from rubber harness, and then simply unplug the drive. Basically, this was a good doc; it got me going in the right direction.
Raymond L Atkinson - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 38
今までの合計 4,504
