メインコンテンツにスキップ
HP Pavilion g6-1b79dx CD Drive Replacement
必要な工具と部品
  1. HP Pavilion g6-1b79dx CD Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the computer so the bottom is facing up with the battery away from you.
    • Turn off the computer and disconnect the charger.
  2. HP Pavilion g6-1b79dx CD Drive Replacement: 手順 2、 2の画像 1 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 2、 2の画像 2
    • Slide the battery switch to the left until the battery unlatches from the base of the laptop.
  3. HP Pavilion g6-1b79dx CD Drive Replacement: 手順 3、 2の画像 1 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 3、 2の画像 2
    • Lift the battery from its compartment away from the laptop.
  4. HP Pavilion g6-1b79dx CD Drive Replacement, Bottom Panel: 手順 4、 1の画像 1
    • Loosen the two 5.7 mm screws on the bottom panel using a PH00 screwdriver.
    • The screws do not come out of the panel due to small washers. Do not try to remove the screws completely.
  5. HP Pavilion g6-1b79dx CD Drive Replacement: 手順 5、 1の画像 1
    • Use the metal spudger all around the panel to pop it up from the base.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Using your finger is acceptable but not entirely recommended. Be gentle if you choose to use your hands.
  6. HP Pavilion g6-1b79dx CD Drive Replacement: 手順 6、 3の画像 1 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 6、 3の画像 2 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 6、 3の画像 3
    • With your hands, lift the panel completely off the base of the laptop.
  7. HP Pavilion g6-1b79dx CD Drive Replacement, CD Drive: 手順 7、 2の画像 1 HP Pavilion g6-1b79dx CD Drive Replacement, CD Drive: 手順 7、 2の画像 2
    • Using the PH 00 screwdriver, remove the screw left of the CD drive.
  8. HP Pavilion g6-1b79dx CD Drive Replacement: 手順 8、 3の画像 1 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 8、 3の画像 2 HP Pavilion g6-1b79dx CD Drive Replacement: 手順 8、 3の画像 3
    • Slide the CD drive out from the exterior of the laptop.
終わりに
作成者
2人の作成者と共同で作成されました。
patrickhall
メンバー登録日: 09/23/15
730 ポイント
3のガイドは作成済み
チーム
Baylor, Team 10-12, Williams Fall 2015 Baylor, Team 10-12, Williams Fall 2015人のメンバー
BU-WILLIAMS-F15S10G12
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 500
