メインコンテンツにスキップ
HP Pavilion g4-1117dx Speaker Replacement
必要な工具と部品
  1. HP Pavilion g4-1117dx Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Slide pill shaped tab to the other side of the channel.
    • Remove battery while keeping the tab to the side.
  2. HP Pavilion g4-1117dx Speaker Replacement, L-Shaped Back Panel: 手順 3、 1の画像 1
    • Unscrew the two screws JIS #0 located on opposites sides of the panel.
    • Screws are attached to the panel and will not fully come out.
  3. HP Pavilion g4-1117dx Speaker Replacement: 手順 4、 1の画像 1
    • Carefully pry off the L-shaped panel.
  4. HP Pavilion g4-1117dx Speaker Replacement, Hard Drive: 手順 5、 1の画像 1
    • Pull out and unplug the tab on the right hand side.
  5. HP Pavilion g4-1117dx Speaker Replacement, Larger Back Panel: 手順 6、 1の画像 1
    • Unscrew all nine 6.0mm JIS #0 screws located on the border of the back panel.
  6. HP Pavilion g4-1117dx Speaker Replacement: 手順 7、 1の画像 1
    • Remove 3 screws located where the battery previously was.
  7. HP Pavilion g4-1117dx Speaker Replacement: 手順 8、 2の画像 1 HP Pavilion g4-1117dx Speaker Replacement: 手順 8、 2の画像 2
    • Remove 6 screws located under the spot where the smaller L-shaped panel was located.
  8. HP Pavilion g4-1117dx Speaker Replacement: 手順 9、 1の画像 1
    • Slowly pry off the keyboard from the back panel.
    • Between the back panel and the keyboard there are two ribbon wires.
    • Remove slowly to not break the back panel. If it does not come off easily, check to see if all screws are removed.
  9. HP Pavilion g4-1117dx Speaker Replacement: 手順 10、 1の画像 1
    • Unplug wires connecting back panel to keyboard.
  10. HP Pavilion g4-1117dx Speaker Replacement, Speaker: 手順 11、 2の画像 1 HP Pavilion g4-1117dx Speaker Replacement, Speaker: 手順 11、 2の画像 2
    • Unplug the red and white wires.
  11. HP Pavilion g4-1117dx Speaker Replacement: 手順 12、 1の画像 1
    • Remove the speakers.
終わりに
作成者
1人の作成者と共同作成されました。
Robert Hamilton
メンバー登録日: 03/01/18
1,165 ポイント
10のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G7, Simcock Spring 2018 UMass Dartmouth, Team S2-G7, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G7
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 601
