Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
Locate the panel that lies in the front center of the laptops underside.
Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
Lift off the cover to expose the Wi-Fi card underneath.
Locate the Wi-Fi card inside of the computer.
With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
Lift the card from its resting location. Be careful, the card and attached wires are fragile.
Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
