メインコンテンツにスキップ
HP Pavilion dv9000 Wireless Card Replacement
必要な工具と部品
  1. HP Pavilion dv9000 Wireless Card Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 手順 2、 2の画像 1 HP Pavilion dv9000 Wireless Card Replacement, Battery Removal: 手順 2、 2の画像 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 1 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 2 HP Pavilion dv9000 Wireless Card Replacement, Wireless Card: 手順 3、 3の画像 3
    • Locate the panel that lies in the front center of the laptops underside.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws on the forward end of the cover.
    • Lift off the cover to expose the Wi-Fi card underneath.
  4. HP Pavilion dv9000 Wireless Card Replacement: 手順 4、 3の画像 1 HP Pavilion dv9000 Wireless Card Replacement: 手順 4、 3の画像 2 HP Pavilion dv9000 Wireless Card Replacement: 手順 4、 3の画像 3
    • Locate the Wi-Fi card inside of the computer.
    • With a Phillips #1 screwdriver, remove the two 11mm screws on either side of the wires attached to the top of the Wi-Fi card.
    • Lift the card from its resting location. Be careful, the card and attached wires are fragile.
  5. HP Pavilion dv9000 Wireless Card Replacement: 手順 5、 2の画像 1 HP Pavilion dv9000 Wireless Card Replacement: 手順 5、 2の画像 2
    • Carefully pop the wires off of the Wi-Fi card. They should easily come off with a light tug.
    • As you take each wire off, keep track of the numbered labels. These numbers correspond with contact points on the card.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Erik Hoffnagle
メンバー登録日: 04/11/13
750 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G32
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 16
今までの合計 3,944
