Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
Locate the middle plastic cover on the bottom of the laptop.
Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
Lift and remove the plastic cover.
Locate the RAM card and the metal tabs on either side of it.
Press both tabs away from the RAM card to release it. The card should flip up towards you.
Carefully lift the RAM card out.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
