メインコンテンツにスキップ
HP Pavilion dv9000 Keyboard Replacement
必要な工具と部品
  1. HP Pavilion dv9000 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Keyboard Replacement, Battery Removal: 手順 2、 2の画像 1 HP Pavilion dv9000 Keyboard Replacement, Battery Removal: 手順 2、 2の画像 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Keyboard Replacement, Keyboard: 手順 3、 2の画像 1 HP Pavilion dv9000 Keyboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Remove the six 5 mm screws in the battery compartment using Phillips #1 screwdriver.
    • Remove the 7mm keyboard screw located towards the center of the laptop with a Phillips #1 screwdriver.
  4. HP Pavilion dv9000 Keyboard Replacement: 手順 4、 1の画像 1
    • Flip the laptop over and open the lid.
    • Lift out the plastic panel containing the power button and flip it over.
    • Be careful, the panel is still attached by a small ribbon cable.
  5. HP Pavilion dv9000 Keyboard Replacement: 手順 5、 3の画像 1 HP Pavilion dv9000 Keyboard Replacement: 手順 5、 3の画像 2 HP Pavilion dv9000 Keyboard Replacement: 手順 5、 3の画像 3
    • Locate the ribbon cable attached to the underside of the plastic panel.
    • Using a spudger, unplug the ribbon cable by pushing the brown tab away from circuit board and sliding the ribbon out with your hand.
    • Set the plastic panel aside.
  6. HP Pavilion dv9000 Keyboard Replacement: 手順 6、 3の画像 1 HP Pavilion dv9000 Keyboard Replacement: 手順 6、 3の画像 2 HP Pavilion dv9000 Keyboard Replacement: 手順 6、 3の画像 3
    • Using a Phillips #1 screwdriver, remove the three 5mm screws holding the keyboard in place.
    • Carefully lift the keyboard up (no more than a few cm) and slide it forward, towards the laptops monitor to reveal another larger ribbon cable.
    • Be extremely careful as the keyboard is still attached to the computer by the larger ribbon cable.
  7. HP Pavilion dv9000 Keyboard Replacement: 手順 7、 3の画像 1 HP Pavilion dv9000 Keyboard Replacement: 手順 7、 3の画像 2 HP Pavilion dv9000 Keyboard Replacement: 手順 7、 3の画像 3
    • Use a spudger to push the black tab forward and slide it away from the white connector.
    • Gently pull the ribbon cable from the connector housing.
    • Remove the keyboard.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Erik Hoffnagle
メンバー登録日: 04/11/13
768 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G32
4 メンバー
6のガイドは作成済み
コメント 1 件
Please I have a problem with my hp laptop the keyboard and there is noise on it, repair it automatic. thanks you
Clement Glah - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 3,187
