メインコンテンツにスキップ
HP Pavilion dv9000 Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion dv9000 Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over to expose the bottom side.
    • Locate the battery removal switch next to the battery compartment
    • Important: Before doing any repairs on the laptop, make sure it is completely powered down and unplugged.
  2. HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: 手順 2、 2の画像 1 HP Pavilion dv9000 Hard Drive Replacement, Battery Removal: 手順 2、 2の画像 2
    • Slide the switch all the way to the left to release the battery. The battery should pop up.
    • Lift the battery out.
  3. HP Pavilion dv9000 Hard Drive Replacement, Hard Drive: 手順 3、 1の画像 1
    • There are two hard drive bays.
    • Hard drive bay 1 is in the lower right corner.
    • Hard drive bay 2 is in the lower left corner.
  4. HP Pavilion dv9000 Hard Drive Replacement: 手順 4、 2の画像 1 HP Pavilion dv9000 Hard Drive Replacement: 手順 4、 2の画像 2
    • To remove hard drive 1 from bay 1
    • Using a Phillips #1 screwdriver, remove the two 5 mm screws that hold the bay 1 cover in place.
    • The screws should remain in the cover.
  5. HP Pavilion dv9000 Hard Drive Replacement: 手順 5、 2の画像 1 HP Pavilion dv9000 Hard Drive Replacement: 手順 5、 2の画像 2
    • After removing the two cover screws, lift and slide the cover out of position to access the hard drive.
    • Grab the clear plastic pull tab on top of the hard drive to lift the hard drive from the laptop.
  6. HP Pavilion dv9000 Hard Drive Replacement: 手順 6、 3の画像 1 HP Pavilion dv9000 Hard Drive Replacement: 手順 6、 3の画像 2 HP Pavilion dv9000 Hard Drive Replacement: 手順 6、 3の画像 3
    • To remove hard drive 2 from bay 2.
    • Most laptops don't have a second hard drive. If yours does not, then proceed to the next step.
    • Using a Phillips #1 screwdriver remove the two 5 mm screws that hold the bay 2 cover in place.
    • Grab the clear plastic pull tab on top of the hard drive, and lift the hard drive from the laptop.
  7. HP Pavilion dv9000 Hard Drive Replacement: 手順 7、 3の画像 1 HP Pavilion dv9000 Hard Drive Replacement: 手順 7、 3の画像 2 HP Pavilion dv9000 Hard Drive Replacement: 手順 7、 3の画像 3
    • After the hard drive has been removed from the laptop, it must then be removed from its bracket.
    • Start by gently pulling the HP hard drive adapter from the end of the hard drive.
    • Using a Phillips #1 screwdriver, remove the four 3 mm bracketing screws on both sides of the hard drive bracket (2 per side) .
    • Lift the hard drive from its metal bracket.
    • Be careful not to touch the green underside as this may damage the hard drive.
終わりに
7 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Robby Cabri
メンバー登録日: 01/23/14
172 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 10-32, Maness Winter 2014 Cal Poly, Team 10-32, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S10G32
4 メンバー
6のガイドは作成済み
4 件のコメント
Hello. In step 7 of the above, what is the name/part number/ size etc of the adapter/connector please ? I need one urgently.
Thanks.
freeflyshannon - 返信
yes that would be very helpfull because the new SSdrive I have will not fit even though is is the same size. I think I need some sort of an adaptor as you say.
Stephen Cox - 返信
For modern SATA SSDs, the typical form factor is 7.5mm. The standard for laptop HDDs is 9.5mm. You will need to buy a plastic spacer in order to properly mount the drive inside your computer.
Michael - 返信
thanks for the help
Stephen Cox - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 8,924
