メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Pavilion dv7-1285dx RAM Replacement
必要な工具と部品
  1. HP Pavilion dv7-1285dx RAM Replacement, Battery: 手順 1、 1の画像 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx RAM Replacement, Back Plate: 手順 2、 1の画像 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx RAM Replacement: 手順 3、 2の画像 1 HP Pavilion dv7-1285dx RAM Replacement: 手順 3、 2の画像 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx RAM Replacement, RAM: 手順 4、 1の画像 1
    • Rotate the device 90 degrees to the left.
  5. HP Pavilion dv7-1285dx RAM Replacement: 手順 5、 3の画像 1 HP Pavilion dv7-1285dx RAM Replacement: 手順 5、 3の画像 2 HP Pavilion dv7-1285dx RAM Replacement: 手順 5、 3の画像 3
    • Locate the grey clips on the side of the RAM and pull the grey clips away from the RAM using the plastic opening tool.
  6. HP Pavilion dv7-1285dx RAM Replacement: 手順 6、 3の画像 1 HP Pavilion dv7-1285dx RAM Replacement: 手順 6、 3の画像 2 HP Pavilion dv7-1285dx RAM Replacement: 手順 6、 3の画像 3
    • Unplug the RAM.
    • Repeat step 6 to remove the second piece of RAM.
  7. HP Pavilion dv7-1285dx RAM Replacement: 手順 7、 2の画像 1 HP Pavilion dv7-1285dx RAM Replacement: 手順 7、 2の画像 2
    • These steps are important in the replacement of the RAM, they will assist in ensuring the device is not damaged.
    • Align the notch in the new RAM with the peg on the plug
    • Ensure the RAM is fully inserted into the plug at a 45 degree angle such that the notch of the RAM lines up with the peg on the plug
  8. HP Pavilion dv7-1285dx RAM Replacement: 手順 8、 2の画像 1 HP Pavilion dv7-1285dx RAM Replacement: 手順 8、 2の画像 2
    • Push down gently on the RAM until the grey clips click.
    • Repeat steps 7 and 8 to replace the second piece of RAM.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jesse Quisido
メンバー登録日: 04/14/14
489 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G34
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 26
今までの合計 1,328
