メインコンテンツにスキップ
HP Pavilion dv7-1285dx Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion dv7-1285dx Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Ensure the device is powered down and unplugged.
    • Turn the device upside down with the battery compartment facing you.
    • Slide the black slider to the right and lift the battery out of its compartment.
  2. HP Pavilion dv7-1285dx Hard Drive Replacement, Back Plate: 手順 2、 1の画像 1
    • Locate and remove the six Phillips PM2.5×7.0 screws around the perimeter of the back plate.
    • These screws do not completely detach from the device when unscrewed.
  3. HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 3、 2の画像 2
    • Use the plastic opening tool to lift up the back plate and set it aside.
  4. HP Pavilion dv7-1285dx Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 1 HP Pavilion dv7-1285dx Hard Drive Replacement, Hard Drive: 手順 4、 2の画像 2
    • Rotate the device 180 degrees.
    • Locate the 2 black Phillips PM2.5×7.0 screws on the right side of the hard drive case and unscrew them.
  5. HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 5、 3の画像 1 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 5、 3の画像 2 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 5、 3の画像 3
    • Use the clear pull tab located on the left side of the hard drive case to unplug the hard drive by carefully pulling it to the left. Some force may be required.
    • After removing the hard drive, orient it such that the label face is up.
  6. HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 6、 2の画像 1 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 6、 2の画像 2
    • Remove the 4 Phillips head screws located on the sides of the hard drive (two per side).
  7. HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 7、 3の画像 1 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 7、 3の画像 2 HP Pavilion dv7-1285dx Hard Drive Replacement: 手順 7、 3の画像 3
    • Hold the case as shown and use your thumbs to gently slide the hard drive out of its case.
    • Transfer the screws to the new hard drive case.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jesse Quisido
メンバー登録日: 04/14/14
489 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-34, Maness Spring 2014 Cal Poly, Team 12-34, Maness Spring 2014人のメンバー
CPSU-MANESS-S14S12G34
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 15
今までの合計 3,627
