メインコンテンツにスキップ
はじめに
This is for if you need to get into the guts of the HP Pavilion dv6700. Be sure to have the anti-static strap on, as you will be coming into contact with circuitry and could permanently damage the pieces with static electricity.
  1. HP Pavilion dv6700 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Locate the battery on the bottom of your laptop.
  2. HP Pavilion dv6700 Motherboard Replacement: 手順 2、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 2、 2の画像 2
    • Slide the tab all the way over to the left until battery pops out. Lift out and remove battery.
  3. HP Pavilion dv6700 Motherboard Replacement, Display/Monitor: 手順 3、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement, Display/Monitor: 手順 3、 2の画像 2
    • Remove the RAM port cover by unscrewing the two screws.
    • These screws will can’t be fully removed because they’re captive. Loosen them until they turn freely.
  4. HP Pavilion dv6700 Motherboard Replacement: 手順 4、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 4、 2の画像 2
    • Remove Hard Disk Drive (HDD) cover by unscrewing the two screws.
    • Screws will not fully remove. Loosen them until they turn freely.
  5. HP Pavilion dv6700 Motherboard Replacement: 手順 5、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 5、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 5、 3の画像 3
    • Remove screws from the bottom.
  6. HP Pavilion dv6700 Motherboard Replacement: 手順 6、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 6、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 6、 3の画像 3
    • Detach WiFi antenna wires.
    • Be sure that the wires are labeled so you remember which ones go where.
  7. HP Pavilion dv6700 Motherboard Replacement: 手順 7、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 7、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 7、 3の画像 3
    • Remove two screws.
    • Use a needle-nose pliers to do the initial loosening, then switch to using a hex screwdriver (size 5) head to do the rest of the loosening.
  8. HP Pavilion dv6700 Motherboard Replacement: 手順 8、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 8、 2の画像 2
    • Flip over HP Pavilion dv6700.
    • Open up HP Pavilion dv6700.
  9. HP Pavilion dv6700 Motherboard Replacement: 手順 9、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 9、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 9、 3の画像 3
    • Use plastic opening tool to pry open the plastic bar above the keyboard.
    • Be careful not to yank so hard that you rip out the ribbon cables underneath. There is enough room to pull safely, but use control to prevent damage.
  10. HP Pavilion dv6700 Motherboard Replacement: 手順 10、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 10、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 10、 3の画像 3
    • Pull out and up on keyboard to remove it.
    • Do not yank it all of the way out, as there is a ribbon cable underneath.
    • Slide the two black locks on the side of the keyboard cable connection port up to release the cable.
    • Grip the ribbon cable near the connection point and gently but firmly pull it out.
  11. HP Pavilion dv6700 Motherboard Replacement: 手順 11、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 11、 2の画像 2
    • Flip over the plastic bar.
    • Detach the display connector.
    • Do not pull on the wires. Pull on the black plastic part or wedge a plastic opener or fingernail between the port and the connector.
  12. HP Pavilion dv6700 Motherboard Replacement: 手順 12、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 12、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 12、 3の画像 3
    • Detach the ribbon cables.
    • Pull from the area closest to the connection port gently but firmly.
  13. HP Pavilion dv6700 Motherboard Replacement: 手順 13、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 13、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 13、 3の画像 3
    • Pull up on tape holding down wires.
  14. HP Pavilion dv6700 Motherboard Replacement: 手順 14、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 14、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 14、 3の画像 3
    • Pull up on the WiFi wires and out from under the metal tabs.
    • Do not yank them out. Let them hang loose once they are out from under the tabs.
  15. HP Pavilion dv6700 Motherboard Replacement: 手順 15、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 15、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 15、 3の画像 3
    • Disconnect the connector from the port.
    • Remove the wire from under the metal tabs.
    • Let wire hang loose after removing under the tabs.
  16. HP Pavilion dv6700 Motherboard Replacement: 手順 16、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 16、 2の画像 2
    • Remove the black screw in the top right corner.
  17. HP Pavilion dv6700 Motherboard Replacement: 手順 17、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 17、 2の画像 2
    • Pull upward on the screen connector tab.
    • It will be firmly secured, so don't be afraid to use a little extra force to pull it off.
  18. HP Pavilion dv6700 Motherboard Replacement: 手順 18、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 18、 2の画像 2
    • Remove the black screw from the top left corner.
    • Keep your hand on the screen to secure it, as once you remove this screw, it will come loose.
    • Lift the screen off and set it aside.
  19. HP Pavilion dv6700 Motherboard Replacement, Motherboard: 手順 19、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement, Motherboard: 手順 19、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement, Motherboard: 手順 19、 3の画像 3
    • Unscrew the black screw in the top right corner.
    • Pull up on the top piece and remove it.
  20. HP Pavilion dv6700 Motherboard Replacement: 手順 20、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 20、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 20、 3の画像 3
    • Remove screw in top left corner.
    • Remove screws on motherboard cover.
    • Pull up on the cover to remove it.
    • You can use a plastic opener if it is hard to get your fingers under the cover's edges.
    • Do not pull hard on the cover, as there are two ribbon cables under the cover connected to the motherboard.
  21. HP Pavilion dv6700 Motherboard Replacement: 手順 21、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 21、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 21、 3の画像 3
    • Pull gently but firmly on the ribbon cables at the connection points to remove them
  22. HP Pavilion dv6700 Motherboard Replacement: 手順 22、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 22、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 22、 3の画像 3
    • Remove screws from the ExpressCard component.
  23. HP Pavilion dv6700 Motherboard Replacement: 手順 23、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 23、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 23、 3の画像 3
    • Remove ExpressCard component by sliding it out.
    • Remove Optical Drive by sliding it out.
  24. HP Pavilion dv6700 Motherboard Replacement: 手順 24、 2の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 24、 2の画像 2
    • Detach connector from the motherboard.
    • This piece is likely to be very hard to disconnect, so do not be afraid to use more force than normal.
  25. HP Pavilion dv6700 Motherboard Replacement: 手順 25、 1の画像 1
    • Remove screw near where the ExpressCard component was.
  26. HP Pavilion dv6700 Motherboard Replacement: 手順 26、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 26、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 26、 3の画像 3
    • Lift up motherboard.
    • Detach the motherboard connector at the front under the motherboard.
  27. HP Pavilion dv6700 Motherboard Replacement: 手順 27、 3の画像 1 HP Pavilion dv6700 Motherboard Replacement: 手順 27、 3の画像 2 HP Pavilion dv6700 Motherboard Replacement: 手順 27、 3の画像 3
    • Lift up and out the motherboard.
    • Detach the connector under the motherboard.
    • Remove the motherboard.
    come si fà a pulire o stappare le canaline in rame di raffreddamento del processore?
    Giorgio D'Ulizia - 返信
    To clean, use cotton or cotton swabs with isopropyl alcohol. Be sure to let it fully dry before putting back together.
    Google translate English to Italian: Per pulire, utilizzare cotton o cotton fioc con alcol isopropilico. Assicurati di lasciarlo asciugare completamente prima di rimontarlo.
    Alec Gramm -
    Sir mother board of a dv 6000 and dv 6700 the same?
    Fernando - 返信
    I do not believe that they are.
    Alec Gramm -
終わりに
8 の人々がこのガイドを完成させました。
Alec Gramm
メンバー登録日: 2015年10月01日
1,228 ポイント
5のガイドは作成済み
チーム
2 件のコメント
Brilliant presentation.
Great Help
Thanks
ivor - 返信
Thank you for all your help . Very decent of you.
Spot on guide and detail.
Ian, Poynton< Cheshire
UK.
558vulcanxh - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 2,891
