メインコンテンツにスキップ
HP Pavilion dv6500 Keyboard Replacement
必要な工具と部品
  1. HP Pavilion dv6500 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Flip computer face down.
  2. HP Pavilion dv6500 Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the battery by sliding the button to the side.
    • Be careful if the battery is leaking or appears punctured in anyway. Battery acid is harmful and may cause burns.
  3. HP Pavilion dv6500 Keyboard Replacement, Back Panel: 手順 3、 1の画像 1
    • Remove fifteen 7.0mm PH0 screws.
    • Remove five silver 4.0mm PH 0 screws inside the cavity for the battery.
  4. HP Pavilion dv6500 Keyboard Replacement, Keyboard: 手順 4、 2の画像 1 HP Pavilion dv6500 Keyboard Replacement, Keyboard: 手順 4、 2の画像 2
    • Gently lift the plastic panel on the top of the laptop at the divide until the two ribbon cables and cable leads are visible with their ports on left side on laptop.
    even taking every screw you said off... this will break before it comes loose. I don't understand...
    poetfreak - 返信
  5. HP Pavilion dv6500 Keyboard Replacement: 手順 5、 1の画像 1
    • Gently pull on the 2 ribbon cables until they detach from the computer.
    • Unplug cables connecting the top keyboard assembly and computer body.
    • Be careful not to rip the speaker cables.
  6. HP Pavilion dv6500 Keyboard Replacement: 手順 6、 1の画像 1
    • The top of the keyboard should be exposed enough to unclip and slide the keyboard out from the clips near the trackpad on the laptop.
    • Gently pull the flat black cable toward the monitor to remove the cable from the motherboard, freeing the keyboard.
    • Be careful not to pull too hard and damage the black cable.
  7. HP Pavilion dv6500 Keyboard Replacement: 手順 7、 1の画像 1
    • Insert new keyboard by sliding it into place of original keyboard and clipping into place near top of trackpad.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
ollie
メンバー登録日: 10/20/16
575 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-6, Catania Fall 2016 UMass Dartmouth, Team 1-6, Catania Fall 2016人のメンバー
UMASSD-CATANIA-F16S1G6
3 メンバー
7のガイドは作成済み
コメント 1 件
Je constate que régulièrement, il n’est pas mentionné de se décharger de son électricité statique. En dehors de tout équimement spécifique, il suffit, par exemple de toucher le bouton de purge d’un radiateur de chauffage central ou la fiche “terre” d’une prise 2 + T
Bernard RUETTE - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 1,594
