メインコンテンツにスキップ
HP Pavilion dv6000 Speaker Bar Replacement
必要な工具と部品
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: 手順 1、 1の画像 1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: 手順 2、 1の画像 1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: 手順 3、 1の画像 1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: 手順 4、 1の画像 1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Joba Fett
メンバー登録日: 04/11/14
227 ポイント
1ガイドが承認済み
2 件のコメント
how to fix speaker from board
kingsley Osunkwo - 返信
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 3,478
