メインコンテンツにスキップ
HP Pavilion dv6000 Hard Drive Replacement
必要な工具と部品
  1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 1 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: 手順 1、 2の画像 2
    • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
    this was very unexpected place to find the answer to my dilemma being unable to figure this hp silliness out; for a couple of months i sat on the upgrade of this almost unusable laptop. i was going to just list it as mostly junk on ebay. all it was is a stupid hp ssd adapter!? i kept looking for an adapter to go the other way unaware it was already there that is why it did not make sense! im trying not to scream! anyway thanks to this wonderful site my laptop is now much more ready to sell as vintage. all it took was a simple photo and sentence "remove the adapter from the hdd"!
    D C Gubler - 返信
  2. HP Pavilion dv6000 Hard Drive Replacement: 手順 2、 2の画像 1 HP Pavilion dv6000 Hard Drive Replacement: 手順 2、 2の画像 2
    • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
  3. HP Pavilion dv6000 Hard Drive Replacement: 手順 3、 2の画像 1 HP Pavilion dv6000 Hard Drive Replacement: 手順 3、 2の画像 2
    • Now you have your hard drive out!
  4. HP Pavilion dv6000 Hard Drive Replacement: 手順 4、 2の画像 1 HP Pavilion dv6000 Hard Drive Replacement: 手順 4、 2の画像 2
    • Gently pull forward the HP adapter from the top of the hard drive.
    • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
終わりに
19 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Ben Hirsch
メンバー登録日: 10/05/10
3,826 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G33
4 メンバー
12のガイドは作成済み
2 件のコメント
thanks for your help
moyguens - 返信
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 39
今までの合計 41,201
