メインコンテンツにスキップ
HP Pavilion dv6000 Camera Replacement
必要な工具と部品
  1. HP Pavilion dv6000 Camera Replacement, Camera: 手順 1、 2の画像 1 HP Pavilion dv6000 Camera Replacement, Camera: 手順 1、 2の画像 2
    • Remove rubber screw covers from the LCD screen. They cover the screws. The stops on the top of the screen pop off, but the lower covers require a screwdriver to remove.
    • If you need to use the screwdriver to remove the rubber screw covers, gently push the screwdriver down the edge of the stopper and then use the screwdriver as a lever to pry the cover from the hole.
    • Remove the six 7.15mm screws underneath the stoppers. There are four on top and two on bottom.
  2. HP Pavilion dv6000 Camera Replacement: 手順 2、 3の画像 1 HP Pavilion dv6000 Camera Replacement: 手順 2、 3の画像 2 HP Pavilion dv6000 Camera Replacement: 手順 2、 3の画像 3
    • Press the tabs in on the sides of the screen and pop the plastic covering off.
    • The edges of the LCD screen are very sharp. Take care to not cut your fingers!
  3. HP Pavilion dv6000 Camera Replacement: 手順 3、 1の画像 1
    • Lift the screen out of the casing at the top near the camera.
    • Take care to not snap the plastic casing! It is brittle and still attached to the bottom of the screen.
  4. HP Pavilion dv6000 Camera Replacement: 手順 4、 1の画像 1
    • Gently remove the main cable from the camera.
  5. HP Pavilion dv6000 Camera Replacement: 手順 5、 2の画像 1 HP Pavilion dv6000 Camera Replacement: 手順 5、 2の画像 2
    • There are three clasps holding the camera down. Gingerly lift the camera board up, being careful not to snap the board, clasps, or vertical plastic pins (inside the gold-colored rings).
    • The metal tabs to the left and right of the camera (for the LCD) are sharp, watch your fingers!
  6. HP Pavilion dv6000 Camera Replacement: 手順 6、 1の画像 1
    • Remove the camera unit from the laptop and you are done!
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Ben Hirsch
メンバー登録日: 10/05/10
3,841 ポイント
10のガイドは作成済み
チーム
Cal Poly, Team 21-33, Regan Fall 2010 Cal Poly, Team 21-33, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G33
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 10,086
